Originally Posted By: Gary Allan
The distortions are probably from the can opening process. Note the pleats are pretty uniform everywhere else but where he took the image.
No breaches ..no goo (would be there if water was present - sorta like a glaze).
Looks okay to me
Cut up and stretch out the media. If you've got a can of brake clean you can spare, just wash down the media. It shouldn't remove any embedded material, but it will clean the stained media.
Almost every filter I've cut open with the exception of the K&N had the pleat distortions in one spot. Doesn't bother me, but I did intentionally take a picture of them. The rest of the media is uniform.
As you can see, the distortion is where they glue the pleats together.
Yes, it is DARK.
I do not have a can of brake clean unfortunately.
It seems to have done some good cleaning, as it appears there is junk in the bottom of the can as well.
We'll see how the Fleetguard looks with the TDT next.....
