I can't deliver what you seek, Falcon. I don't have access to MC, Puro, or Denso data.
There are some oddities here you may find interesting.
Donaldson doesn't consider the FL910 and the FL793 to be the same filter. The 910 is considered a hydraulic filter. Put either into Wix (and your 90915-20004 into their engine, and you get a 51348 ..which when put into Donaldson ..brings forth a 3rd number.
FL910 MOTORCRAFT P550589 HYDRAULIC SPIN-ON
FL793 MOTORCRAFT P550335 SPIN-ON LUBE FILTER
51348 WIX P502016 LUBE SPIN-ON FULL FLOW
P550335 brings up two numbers in Purolator
L10241
L35098 this one brings up P550400 - which brings up a 51516 in wix.
P502016 brings up L10241
Most of these numbers x'ref in a Fram to PH3614 EXCEPT the FL910 with x'ref's to a PH9566 ..which gives us a 51215 in WIX ..which gives us a P552430 Donaldson.
I know that didn't help you, but I thought you might like to see the breeder reactor effect one or two part numbers can create
