Well, I decided to cut open a brand new Motorcraft FL-820S to see what the initial quality would be. This filter was purchased in the last quarter of 2015 and carries a recent date code 909031527. Filter constructed on Sep 3, 2015. About 4 months old. Stored in the house not in the garage.
FL-820S-909031527 #1 Here is the exterior of what many call a good filter.
FL-820S-909031527 #2 Exterior shot of the base plate.
FL-820S-909031527 #3 Interior shot of the base plate
FL-820S-909031527 #4 Silicone ADBV base plate side.
FL-820S-909031527 #5 ADBV filter side.
FL-820S-909031527 #6 Bypass valve inlets. At some point in time Motorcraft/Purolator changed the number of inlet holes to the bypass valve from 4 to 8 holes. I believe this design change very well help solve the media tearing issue. So far so good.
FL-820S-909031527 #7 uneven pleats at the splice. This shot clearly shows wide pleat spacing near the splice before installation.
FL-820S-909031527 #8 uneven pleats at the splice closeup near the dome end.
fl-820s-909031527 #9 uneven pleat spacing at splice closeup near the thread end.
FL-820S-909031527 #10 even pleat spacing is demonstrated away from the splice.
FL-820S-909031527 #11 even pleat spacing but notice the brown stuff on the left bottom.
FL-820S-909031527 #12 even pleat spacing note the rust.
FL-820S-909031527 #13 note the rust.
FL-820S-909031527 #14 note the rust closeup. This rust also appeared on the inside of the filter on the dome end end cap. I could not get a decent photo of this due to lighting. You can also begin to the the delamination between the epoxy and the end cap because of the rust.
FL-820S-909031527 #15 side by side with PH820 element on the left and the FL-820S element on the right. This particular eCore does have some issues that I will show in another post.
Here are the reference links to the used FL820S I have already cut & post.
Motorcraft FL820S cut open Date code: 904121217 #3994569
https://bobistheoilguy.com/forums/ubbthreads.php/topics/3996687/1
This is Motorcraft FL820S Date code: 906241527. #3994586
https://bobistheoilguy.com/forums/ubbthreads.php/topics/3994586
I was pleased to see they did make some design changes but, the wide pleat spacing near the splice is still very evident. I think the rust issue is very poor. I have to assume this may impact other Motorcraft part numbers not just the FL820S.
If you are using Motorcraft filters, I would recommend you cut a few of them open and see if you have any issues.
Because of the recent autopsies on used filters and tear downs of new filters, I will not be using Motorcraft FL-820S filters and will be looking elsewhere.
I hope this does not cause too many of you undue stress.
Thanks for reading.
Thanks for reading.
