miles on vehicle at time of sample 15,730
make-up oil added: 0qts
vehicle tested/universal averages
Aluminum - 1 4
Chromium - 0 1
Iron - 7 19
Copper - 8 9
Lead - 0 1
Tin - 0 1
Moly - 2 44
Nickel - 0 1
Manganese- 0 3
Silver - 0 0
Titanium - 0 0
Potassium- 0 0
Boron - 0 45
Silicon - 14 15
Sodium - 0 30
Calcium - 1921 1888
Magnesium- 13 396
Phosphorus-723 773
Zinc - 781 912
Barium - 0 3
TBN - 2.7
viscosity- 52.6
Flashpoint-385
Fuel - 0.5
Antifreeze-0.0
water - 0.0
insolubles-0.5
Blackstone's comments- The viscosity of this oil was just slightly low for a 5w20, but we didn't find any gas or other contaminants in the oil that would cause a viscosity shift. Universal averages show typical wear metals for an oil from this type of engine after about 4,550 miles run on the oil. Your oil was in use 3,268 miles, and we found all wear at better than average levels. Air and oil filtration were working okay while this oil was in use. No moisture or anti-freeze found. The oil could have stayed in use longer. The TBN was 2.7, showing a little active additive left, though not much.
Alright guys, let me know what you think!
By the way, this oil was in service for about 5 months. I am currently running Penzoil to compare, I will post results when I change next. Thank's in advance for any comments!
Aluminum - 1 4
Chromium - 0 1
Iron - 7 19
Copper - 8 9
Lead - 0 1
Tin - 0 1
Moly - 2 44
Nickel - 0 1
Manganese- 0 3
Silver - 0 0
Titanium - 0 0
Potassium- 0 0
Boron - 0 45
Silicon - 14 15
Sodium - 0 30
Calcium - 1921 1888
Magnesium- 13 396
Phosphorus-723 773
Zinc - 781 912
Barium - 0 3
TBN - 2.7
viscosity- 52.6
Flashpoint-385
Fuel - 0.5
Antifreeze-0.0
water - 0.0
insolubles-0.5
