wemay
Site Donor 2023
Motor Trend: DOHC LT6 Engine in 2023 C8 Corvette Z06: Details and Power.
"Oil is life and to an engine designed for hard road course life a robust oiling system is of upmost importance. In this area, the LT6 engine learned a lot from it's C8.R race-bred cousin. Each piston pair is hermetically sealed off from the other pistons so that the air under the pistons simply back and forth with minimal losses from pumping. The six-bay oil pump, that runs the length of the LT6, scavenges each bay, along with the cylinder heads, and takes 14 hp to operate. The system uses 10 quarts of 5W50 and the rather large cooler is housed in the driver side rear intake. According to Chevrolet track day temps should stay around 250 to 265 degrees."
Flat-Plane Crank DOHC LT6 to Power the 2023 Corvette Z06! Details and Specs
Chevrolet released details on the DOHC 5.5L LT6 engine that will power the new 2023 Corvette Z06. It revs to 8,600 rpm, churns out 670 hp, is stuffed with innovative tech, and will power the new Corvette C8 Z06 supercar! This is the closest you can get to having a C8.R race engine in you Corvette!
www.motortrend.com
