Life's too short.Unblock that poster, that's half the fun of being on this part of the forum.![]()
I've done this method before and I do it with new cables or if I have to get NOS or even used cables (nb: working with vintage bikes almost exclusively) that will be put on a bike. Otherwise, it tends to be too much of a pain to remove cables and re-route them again just for this method.Someone on a KZ forum site called Motion Pro about the cable lube, and he was told that it's not discontinued, just out of stock. Take that for what it's worth...
Personally, I use regular old motor oil. Make a funnel shape out of foil or a plastic bag, and rubber band it onto the end of the cable while sticking up. Fill the bag with oil, and it will slowly creep down the cable. Wait until you see some oil come out the bottom side.
Regarding oil not being necessary, all I can say is try oil on an old cable, then come back and post here again. It makes a noticeable difference. It may not be needed on a fresh cable, but it does help old ones.
Photo from revzilla... https://www.revzilla.com/common-tre...PPga1tYbjBr27iUEqJWZ2KZEdjq8esxxStSmdaAdKMfLZ
No need to reroute, just disconnect from the hand control and oil, that's enough for most cables.I've done this method before and I do it with new cables or if I have to get NOS or even used cables (nb: working with vintage bikes almost exclusively) that will be put on a bike. Otherwise, it tends to be too much of a pain to remove cables and re-route them again just for this method.
I oil my cables about once a month or so regardless of age.
Nice, sounds similar to the Wurth HHS-K: https://www.wurthusa.com/Chemical-P...nge-Lubricant-Aerosol-Can-500-mL/p/0893106050This is my go to cable lube. Available at any Case or New Holland farm equipment dealer. Used it once on the door hinges of my 2014 Ram and have not had to lube again. Tried every other type before and nothing seemed to work.
Yeah, when I bought a few years ago it was about $20.Dri Slide was the previous one I tried, not cheap either! Initially worked well for my clutch cable, but turned grabby quickly. Then I flushed it out with the garge door lube. That stuff is great and lasts long!
Warm enough that I can ride around a small amount. Lubed the throttle cable on this old Puch Maxi moped that really needed it and freed it right up. Works really well. Didn't even get crazy completely removing the cable and flushing it out. If it lasts longer than PJ-1 I'll be a happy camper.Dri Slide was the previous one I tried, not cheap either! Initially worked well for my clutch cable, but turned grabby quickly. Then I flushed it out with the garge door lube. That stuff is great and lasts long!
