As others pointed out compressors need a lot of power. I just bought a simple dehumidifier, 6A 120V = 720W
Another problem is that you never get 100% of rated panel power. Depnding on clouds, angle, etc. you tend to get much less, say 70% even in sunny places. So 70% of 200W = 140W vs need 720W
Not even close.
"every little bit helps" argument is valid. Unfortunatelly this option will cost minimum $1K, probably closer to the $2K-$3K range. Therefore, it is a rather expensive "little bit that helps"
This money would yield much better results applied to bigger batteries and/or plugin option.
Thus the more likely scenario is a simple high volume air circulation fan keeping interior and batteries cool while parked. This is of little value. As ekpolk pointed out, fuel savings would be great if panels took over the burden of powering compressor. That would be of some value.
My final problem is that panel power is wasted of air circulation which can be done in simpler cheaper ways. Meanwhile, that power is not captured into the main battery!!! What is more, on cooler days with a lot of sunshine when cooling is not needed (spring/autumn) what does panel do with its captured energy????
Given that the panel is expensive, its energy capture must be maximimzed by being always on and sending every last bit of energy into the main battery. That is the only way that the high cost can be justified. Over time, 10-20 years the panel will pay for itself, so long as its use is maximized.
Seems Toyota is not going to do that
