from the piston crowns.... 172k civic 1.5l 1993, did the water thing 3 weeks ago worked pretty good, took most of it off but now its back like it was.....went through a tank of gas with 16oz of MMO and 40oz of paint thinner which was made up of the same junk in MMO... piston crowns are still black.... took off the pcv hose off the pcv valve and sucked in MMO , then did water, then did mmo, then did water... smoked the neighborhood out like a bomb went off.... took off the brake booster line and did paint thinner through there, made it bog down so it would shut off and i was gonna let it sit to soak then fire it back up but it just bogged down real real slow and never cut off so i turned the key off, but it was still bogging....my guess is the paint thinner was still combusting due to chamber temps and pushing the cylinders down..... couldnt shut it off so i redlined it and blew it all out.... still black stuff on piston tops, plugs are gapped correctly...im lost....oil leaking into the chambers and getting cooked on quicker than i can take it off?
