The point is the vis is going to drop more than .05 on a 0-16 oil over 5000 miles. It could be .80 it could .50, it could be .30 but the vis drop is not going to be .05 over 5000 miles. Pick 10 random reports at 5000 miles and the vis drop is going to be more than .05. Show it to me.
Instead of doing random, I went looking for some oils that I expected would have little to no VII in them.
- HPL 0w-20:
quoting the OP from that thread:
RDY4WAR said:
KV100 is 8.5 cSt indicating no oxidative thickening nor shearing.
There was some discussion on here last summer about the ability of a racing oil to go 10,000 miles on the street. It was part of a larger discussion about running lower viscosity oils than the OEM recommendation. I reached out to @High Performance Lubricants with an idea, we discussed it a bit...
bobistheoilguy.com
- Ravenol VSE 0w-20:
Virgin visc is 8.3cSt, Blackstone got 8.33, well within the margin of error for the test.
- AMSOIL SS 0w-20:
Below is the OCA using Amsoil SS 0w20 for about 6k miles in extreme terrain towing a 5000 pound trailer in mountains, desert and extreme cold/heat. I’m most curious on why the viscosity is off. The higher silicon can be attributed to changing the oil pan and the silicone that was used to make...
bobistheoilguy.com
This is an amusing one, it's a short run (6,000 miles) but the oil didn't lose any viscosity, rather, it shows a touch of oxidative thickening, being 9.3cSt vs 8.8cSt as spec'd.
- HPL 5w-20:
This is a sample pulled from my Durango 3.6L with 117,000 miles total and 5,000 miles on the oil. The oil is HP 5w-20 by High Performance Lubricants in Manteno, IL. This oil is intended for extended drain intervals. It's not inexpensive, but it's clear that it holds up very well. I will sample...
bobistheoilguy.com
Virgin spec is 8.75cSt, UOA shows 8.8cSt, so no change, well within the margin of error for the lab.
- Redline 5w-20:
Bizarre comments from Red Line. I sent this to Dave and also messaged Red Line on FB. The response I received back on FB is really bizarre. Have a look. I asked this question before: Assume Red Line or any boutique brand works with an additive supplier and buys an additive package. They then...
bobistheoilguy.com
Virgin spec is supposed to be 9.0cSt, but on this 7,100 mile run it only oxidized (the HEMI isn't a known diluter) to 11.80cSt!
- AMSOIL SS 0w-20:
OLM at 5%. Fram Ultra Cartridge filter. 10 months. Same oil with Amsoil EaO filter went in. I had a magnetic drain plug on, when I loosened it it got the magnet stuck to the side of the drain hole. The oil was coming out at a manageable rate so I filled the sample bottle from there. I wonder...
bobistheoilguy.com
Virgin spec is 8.8cSt, UOA show 8.55cSt, likely a little bit of fuel.
- Redline 5w-20:
Here’s my first UOA on my Durango with a relatively long oil run. I have seen poor performance (low TBN) of Redline in other reports and thought I would post this. I’m completely happy with the job it’s doing to protect this engine. The oil run was also over a two year period, as I don’t drive...
bobistheoilguy.com
Visc spec is 9.0cSt, UOA shows 9.78cSt, indicating some oxidative thickening.
- HPL 0w-8:
Virgin is 5.62cSt, UOA shows 6.3cSt, indicating some oxidative thickening. If you look at his previous reports, the thickening only seemed to start with this latest report, previous showed stable viscosity of 5.7cSt, well within the margin for lab error.
Again, none of this is an ENDORSEMENT for the OP to run a 0w-16 in an application that doesn't call for it. It's simply an explanation as to why there may be little to no observed viscosity loss with certain lubricants in certain applications.
There
will be UOA's of this same oil with more fuel dilution that will show considerable viscosity loss. We may see some in the future where we see significant oxidative thickening, as observed with some of the other oils above. It all comes down to how the lubricant is formulated, operating conditions, and how the application is on oil.
What would be more valuable is if a future UOA is done with Polaris/OAI that uses GC for fuel so that we have a proper understanding of what role fuel is playing. If fuel dilution is at a level that makes it relevant, then we know that it is being offset by oxidative thickening, which is what is keeping the oil right around its original viscosity.
