Originally Posted By: buster
Originally Posted By: MatchboxCar
Originally Posted By: Bill in Utah
The test where you can see sludge and varnish in the engines that ran Mobil 1 Extended Performance for 116k miles?
That's not varnish or sludge. I have nho idea where you came up with that one!
He's a M1 hater. And yes, he is wrong about the varnish/sludge. I don't see any.
Wow. While I do not care for (and have used quite a bit of Mobil 1 and done used oil analysis to show its performance compared to other oils in the same engine) (SO IN ANOTHER WAY, PUT MY $$ WHERE MY MOUTH IS) I don't drink the Mobil 1 koolaid like others here.
If it performs, I call it. If it does not I'll state that. If the photos show something (WHICH THEY DO) lets call it.
If you can not see the varnish in the photos, I can not help that. If you want to call it Mobil 1 "discoloration" since Mobil 1 could NEVER cause any thing to go wrong then fine.
I'm stating that there is what most people would say (and have said when posting photos of their cyl heads on this board) is varnish.
So once we label someone as a "hater" then we will just ignore them and the facts.
Get a better monitor if you can not see the photos.
Quote:
I see no sludge or varnish. That is typical discoloration that will be on any used engine using any oil.
(He sees it, but its called discoloration)
Quote:
I watched the video again; the only parts spread out on the table that weren't varnished were the bearings. The pistons and rods, rod caps, main caps, head and camshafts, gear set and chain; all of those parts were heavily varnished.
He saw it..
You see perfect shiny clean normal metal.
Lets get a sticky for definitions.
Varnish:
what any other oil but Mobil 1 deposits on metal parts.
Quote:
Mobil 1 Extended Performance also scores 3.9 on the industry standard TEOST test (part of GF-4, SM, Ford and Chrysler specs) to evaluate tendency to from sludge and deposits (36% less than regular M1 which scored a 5.3, and 676% less than Syntec's 26.4)
Oh goody, another quote for another "Test/spec".
If the search function on this board did not stink so much, I'd post the photo of the cyl head that was spotless at 200k plus of running Syntec (it did not even have the "discoloring") that is "normal" for all engines that use any oil.
So much for that spec. It it the end result that matters.
Plenty of people use Castrol (and not even syntec) and make their engines last. They don't care about this test or that.
And they use non syn in turbos and they make it down the road.
My biggest point about the "test" (sorry marketing) that Mobil did in Las Vegas was they ran something that should not have run 3 times as long and posted it to their not that well performing EP (as far as cleaning / keeping clean) and DID NOT SHOW ALL THE PARTS FROM BOTH THE EP AND CONVENTIONAL ENGINES.
Instead they took photos of the cars.
Took more photos of the outside of the cabs than engine parts.
Cool, I always love to see cabs.
Take care, Bill (I'll change my user ID to Mobil 1 hater soon)
