Mobil 1 vs PP ?
Tough one but I think PP is ever bit as good and maybe better in some grades than M1. Both are excellent.
depends on the engine and what the company bean counters decide to do.
both companies have lowered their standards to make the bean counters numbers
Mobil 1 used to have a high dose of expensive PAO
PP used to use an exotic base oil
why you messing with these two second class oils when you have Esso 0w20 avail up there in oil elixir land where they still brew top gun oils
im looking for 5w20 ? is Esso 5w20 better then M1 and PP ?
i was sure ESSO oil is same as M1 ? just different labels
if those ones are 2nd class
what are 1st class oils ?
I dunno if they are the exact same, but they are definitely under the same parent company.
Esso oils are brewed in their Sarnia, Ontario lubes operation as far as I know. Mobil1 of course is brewed in the US. I would not assume these are the same product with different packaging just because they have the same parent company.
I prefer Pennzoil Platinum but I have nothing against Mobil 1. Just a personal preference and I also like the fact that I don't pay as much for the Platinum.
Esso doesn't make a 0w20, did you mean their 0w30?
oh they don't, im sorry
so i will not even consider Esso at this point ..
Originally Posted By: synman
Actually M1 in Canada is made by Esso.If you check the back of the label it says made by Esso.
The 0w40 and the TDT I bought recently at Walmart did not say that on the jugs.
M1
Both are great,flip a coin...
im Running penzoil DINO in Toyota, Nissan, and VW .. so Johnny should be happy :P
what about 5w20 Redline Pao Based ?
