I have the Mobil 1 Synthetic Grease, and have used it for years. But I think the Lucas "Red N Tacky" is better, in that it adheres much better because like its name say's, it's very tacky, and it sticks to the applied surface much better.Currently using Lucas Red & Tacky and some Super Lube grease with Syncon (Teflon) for various auto and home use . The Mobil 1 synthetic grease is of interest because it is synthetic - your experiences with using the M1 synthetic Grease ?
Used it many years.Currently using Lucas Red & Tacky and some Super Lube grease with Syncon (Teflon) for various auto and home use . The Mobil 1 synthetic grease is of interest because it is synthetic - your experiences with using the M1 synthetic Grease ?
i use the M1 synthetic grease. it does seperate a bit but other than that it holds up well.
Mine is the one pound tub. It has a plastic snap on top after you open it. Out here in the Summer there is a large puddle of oil on the top that has to be mixed in.When in the store, I remove the 'cap' and look for separation.
The Mobil 1 (years ago) did have oil under the cap.
I have the M1 tub as well. No separation that I can see.Oddly, M1 separates out when it’s sitting in the tube for a long time.
So I don’t use it in tubes anymore.
I use AMSOIL in the grease gun.
But I have a 1 pound tub of Mobil 1 grease that has sat on my workbench, and I’ve used it to lubricate M1 Garands for at least 15 years. It hasn’t separated out at all, and I’ve used maybe a 10th of it.
I reckon I’ve bought all the Mobil 1 grease I will ever need.
I have read where firearms shooters mix the Mobil 1 synthetic grease + Mobil 1 5W30 synthetic oil to the consistency they are trying to achieve for barrel lugs , bolts , slide rails , etc.Oddly, Mobil 1 separates out when it’s sitting in the tube for a long time.
But I have a 1 pound tub of Mobil 1 grease that has sat on my workbench, and I’ve used it to lubricate Mobil 1 Garands for at least 15 years. It hasn’t separated out at all, and I’ve used maybe a 10th of it.
