Grease for polyurethane bushings
SC Coast
Any negative effects by using Lucas red n tacky on polyurethane bushings? Will it have any effects of degrade material?
The bushings are on aftermarket control arms, and super lube is mentioned but it also says any quality synthetic grease is ok
I was hoping to keep from having to buy another tube of grease if possible, and a separate grease gun. .
If the red n tacky works I’ll use that since I have it already in my grease gun.
These arms are fitted with zerks so I really need a tube I can shoot in with the gun
I just don’t want to damage bushing by using wrong type of grease
Silicone based grease is generally good with polyurethane. Look for brake caliper products that are labeled as safe for rubber. Sil Glyde is a good example.
I would ask the manufacturer, I know some poly graphite are very resistant to grease and oils but some poly manufacturers sat not to use a petroleum based products.
I’ve tried everything for lithium complex to super-lube on my Mustang. Longest lasting BY FAR is jet-lube silicone grease nlgi 3.
