Is calcium sulfonate grease OK for poly bushings?
Southern California
Amsoil Synthetic Water-Resistant Grease - a calcium sulfonate complex grease. Amsoil product code GWRCR. NLGI #2 GC-LB.
Would there be any potential problem using this on polyurethane bushings in automotive suspension applications?
Yes, I did several searches but couldn't find this answer - hope I'm not rehashing an old subject.
Thanks!
I'd suggest asking Amsoil, they should be able to give you a technically correct answer. Having said that though I can't imagine the lubricant being a problem for polyurethane.
Had an issue with calcium grease many, many years back swelling poly bushings in trailer brake S-cams causing the brakes to release slow and drag. I don't think it was widespread, the end result answer we got was it was a specific to the particular poly formula in the bushings. We switched back to lithium based grease and problem went away.
