quote:
Originally posted by buster:
quote:
That would surely drop my Fe wear from 9ppm to 7 ppm easily.
I bet the engineers that log onto this site from oil companies get a good laugh at comments made about small differences in PPM wear #'s.
Of that we can be certain. A reality check on just how small a portion a Part in a million is.
What I use at work is the simple
1%=10,000PPM so in essence 1 PPM= .00001%
Other conversions using water(use specific gravity to convert to liquid being measured)
1 part per million (ppm)
= 1 milligram/liter
= 3.8 milligram/gallon
= 2.7 pound/acre foot
= 0.0038 gram/gallon
= 0.0283 gram/cubic foot
= 0.0000623 pound/cubic foot
= 1233 gram/acre foot
= 0.0586 gram/gallon
= 8.34 pound/million gallon
= 1 ounce/1000 cubic foot
= 1 gram/264 gallon
= 1 gram/cubic meter
= 0.134 ounce/1000 gallon
All this is pretty silly with Fe wear. We have no way of knowing if it indicates a linear relationship with wear rates, all we have is assumption that all Fe is or is not directly related to friction wear. I fall on the side of the argument that all Fe cannot be directly related to wear. It is an indicator if the wear numbers in a particular vehicle jump into the hundreds of PPM range youknow it's wear.. A differnce in 20 PPM wear can not be directly related to wear if the oil is a differnt type. IF the oil is the same brand and lot and you see increasing iron numbers you could say with more confidence that more wear is ocuring. If you change brands and immediately see a difference you cannot say it is anything but a change. To many variable have been introduced. Maybe the boron does become iron oxide, maybe the dispersants/detergents have lifted more residue into solution, perhaps even previosly oxidized iron, maybe there is more friction between wearing surfaces or perhaps there is more actual corrossion occuring.. but where? moving wearing parts are that large surface area inside an engine that acts as a container for the oil as it curculates, pumps about and is splashed here and there?
