Originally Posted By: modernrockbro
Originally Posted By: sangyup81
The solution to the VII problem isn't a basestock that eliminates the need for VIIs but the use of better VIIs.
If you really want to look for basestocks with good natural VI, you might be surprised to know Group III has pretty good natural VI even though it originated as a dino before it was hydrocracked. Not quite on the level of Group IV or Group V but it's way cheaper making synthetics affordable even for those who want to do only 5000-7500 OCIs.
So do you guys and gals think it would be better to use a base 3 blend, because of value and do more frequent oil changes vs. using a group 4 base blend and keeping it in longer? If so, how often?
I'm open to any ideas.
I have a new motor, that I'm breaking in, and want to change over to an oil besides the Brad Penn in it here in a week or two. It's an older twin cam motor with dual Weber-style DCOE carbs, and will be revving to about 7000 frequently. My engine produces a lot of heat right now, and I will still have my foot in it after it's broken in. So, I need an oil that won't break down under heat & still flow in this cold North Carolina weather we are having.
Won't break down in heat? Consider Red Line oils, that's what I would use in a car like yours. If you need extra zinc for your cams, they have an additive for that.
There is no doubt they have an oil that would be excellent for your car. Call Dave and ask him, he's very knowledgeable about oils.
Red Line doesn't have different grades of oil, it's all top of the line ester based oil.
http://www.redlineoil.com/products.aspx
