Originally Posted by SR5
Mobil 1 0W40 In Australia
Mobil 1 0W-40 Value
Viscosity, cSt (ASTM D445)
@ 40°C 75
@ 100°C 13.5
Viscosity Index 185
MRV at -40°C, cP (ASTM D4684) 31,000
HTHS Viscosity, mPa•s @ 150°C, (ASTM D4683) 3.8
Total Base Number (ASTM D2896) 11.8
Sulfated Ash, wt% (ASTM D874) 1.3
Phosphorous, wt% (ASTM D4981) 0.1
Flash Point, °C (ASTM D92) 230
Density @15.6 °C, g/ml (ASTM D4052) 0.85
Mobil 1 0W40 In USA
Properties and Specifications
Property
Grade
SAE 0W-40
Ash, Sulfated, mass%, ASTM D874
1.34
Density @ 15 C, g/cm3, ASTM D4052
0.8456
Flash Point, Cleveland Open Cup, °C, ASTM D92
226
Hi-Temp Hi-Shear Viscosity @ 150 C 1x10(6) sec(-1), mPa.s, ASTM D4683
3.6
Kinematic Viscosity @ 100 C, mm2/s, ASTM D445
12.9
Kinematic Viscosity @ 40 C, mm2/s, ASTM D445
70.8
Mini-Rotary Viscometer, Apparent Viscosity, -40 C, mPa.s, ASTM D4684
21600
Phosphorus, mass%, ASTM D4951
0.1
Total Base Number, mgKOH/g, ASTM D2896
12.6
Viscosity Index, ASTM D2270
186
Australia still users the older formula Mobil 1 0W40 which was previously used in North America (NA) but now NA uses Mobil 1 0W40 FS. When NA lost it's BMW LL-01 spec for a bit, Australia kept the spec.
So be careful when comparing Australian Mobil 1 to NA Mobil 1 or Europe Mobil 1. They are all good, but not necessarily the same.
The info on that site is ancient I'd wager. The MSDS search for Australia indeed yields the "FS" version of Mobil 1 0w-40, along with a "non-FS" version which appears identical when glanced at.
This is the current PDS for the Aussie Mobil 1 0w-40 which is indeed the "FS" product and has the same specs as the US (and ROW) one.
