4wd
$50 site donor 2026
What comes after ultra ?Ultra platinum is a GTL. It’s a good oil but not quite on the level of ultra platinum
It will be something else 6 months from now …Super Tech Advanced is as good as Pennzoil Ultra Platinum you do say???
?What comes after ultra ?
royal purpleWhat comes after ultra ?
Can you explain what you mean here?Ultra platinum is a GTL. It’s a good oil but not quite on the level of ultra platinum
It's either Super, or Super Duper.What comes after ultra ?
Again, till you think you seen or heard it all.Not even the same caliber IMO.
That pennzoil ultra platinum is a gas to liquid derived oil and it’s a better product over super tech advanced. Not saying the super tech advanced is bad it’s just not an equal of comparison to ultra platinumCan you explain what you mean here?
Okay, so how does a gas to liquid derived oil work better?That pennzoil ultra platinum is a gas to liquid derived oil and it’s a better product over super tech advanced. Not saying the super tech advanced is bad it’s just not an equal of comparison to ultra platinum
You're on this site long enough. Use the search to seek what you are after.Okay, so how does a gas to liquid derived oil work better?
Thanks, pretty much what I thought.You're on this site long enough. Use the search to seek what you are after.
https://bobistheoilguy.com/forums/search/4367099/?q=GTL&o=relevanceThanks, pretty much what I thought.
From what I have read, it has a more consistent molecular structure and has some advantages in reducing engine deposits.Okay, so how does a gas to liquid derived oil work better?
This is an example of why I think modern hybrids are done entirely wrong. As described above, that's an abusive start to the engine almost every time. Cold start and immediately loaded.We put 150k+ on a Fusion hybrid running Mobil 1 Annual Protection 0W-20 for 10k … what I found odd was you really could not warm it up just coming out of the neighborhood - it stayed electric - So, the first road was 45 MPH and the 2.0L had to grab that cold … Fuel and moisture are what these formulations target …
Well for one thing GTL is also a Group III base, so in that respect it is no different. But yes it can have a higher VI and lower contaminates than some other Group III bases but it's not exclusive. I was just wondering why the other poster thought it resulted in a better finished product.From what I have read, it has a more consistent molecular structure and has some advantages in reducing engine deposits.
So what have you found or what do you know that says it is not superior to Group III? I'm not saying it is, I'm just sharing what I've found and want to hear what you have found that indicates otherwise?
Many companies seem to like it, in spite of it's higher cost, as it seems to be present in some formulations beyond just Pennzoil and Shell.
Much like water is suitable for drinking.This one is interesting.
It has "suitable for hybrids" on the box.
What exactly does "suitable" mean! Ha! Not "designed for". I wonder if this blend has traits/properties that benefit most hybrid vehicles or does it merely meet specs called out for in most hybrid manuals? This one could actually be a bit of marketing genius that grabs folks attention when perusing the Walmart oil aisle.
The price is certainly right at 25 bucks, and 6 quarts is perfect for my application in a 2010 Ford Escape Hybrid. I may go with this instead of the Mobil 1 Hybrid. There certainly has been quite a bit of recent discussion touting Halvoline PRO-DS.
PAOs in a sense are GTL because most of them will start with ethylene gas at some point in the process.From what I have read, it has a more consistent molecular structure and has some advantages in reducing engine deposits.
Sure, but it is the final properties that matter and in your case above it is about chemical structure which is completely different between the two.PAOs in a sense are GTL because most of them will start with ethylene gas at some point in the process.
