Thanks for all the replies!
Since you think its wearing on the top end, you should try QSUD and test out the Ratbag blog theory. No bett time then on thats showing high wear with every other oil. Also, Quakerstate states no other Synthetic provides better wear protection. I would be very interested in seeing how well it stands up to your Ford.
I've tried SOPUS products in the past and I've never been happy with them for various reasons. the consumption I had on Pennzoil Platinum alone was enough to keep me from ever using it again. If QSUD is anything like PP, I have no interest in trying it. Now, if someone wants to donate the 11 quarts it would take me to get through a 7500 mile OCI, i'll give it a try.
The viscosity dropped Close to a 20 !! Try a semi syn or a 0w- 40. new vehicle?
a newer vehicle would be nice, but I've got some other stuff to pay off first if possible.
the motor is spec'd for a 20wt - why would I need to go to a 40wt?
I'd go back to Trop Artic for 5k miles, great results with that one. Esp, that iron reading, wow. I'd also prob put some MMO in there to help lube/clean the top end.
I have thought about trying the trop artic again. that one OCI was all interstate miles accumulated in about 1.5 months, so it is kind of the outlier. the only reason I sampled that time was to see if 5w30 would be OK. it did like it, but that use had no winter and no towing, just lots of long trips in a short period of time.
if I do try it again, I might see if I can stretch it out to 7500. just on the fence. I REALLY don't want to go back to 5000 mile OCI's. that's 4 changes a year and I'm just tired of it.
There is no data from the previous run of mobil one so that isn't particularly relevant, apart from the fact that this run isn't tainted from another brand oil. It's just strange that people try and draw a scientific conclusion from a little snapshot of information. But I suppose that is the curse of BITOG.
a snapshot is about as good as it can get, IMO. I specifically sampled the M1 after the second fill so that I wouldn't have the EDGE skewing the results. IMO, the M1 has spoken for itself, and it is on the no-fly list with Pennzoil, at least for this truck. the Subaru loves it, but it did shear quite a bit in the Subaru, though, wear numbers were excellent.
everyone wants to see back to back to back to back UOA's on the same everything. that's not realistic, especially if you are seeing results you don't like. Why keep trying something with poor results hoping it gets better? if it doesn't, that's 15k or 30k of miles that you could have been using something better. I'm not sure there's another 30k left in the truck! I'm not wasting what time is left on a oil that can't at least produce ONE decent result. this was back to back with M1, so to me it is safe to assume that the last fill probably performed about the same. Based on my two runs of EDGE, that seems like a safe bet. Mobil 1 just didn't perform, I gave it a fair chance.
I see in that UOA that your Potassium & Sodium numbers are elevated. Is it possible you're getting some coolant in your oil and that's causing a loss in lubrication?
anything is possible, I suppose. but I've never had to add any coolant since 2013 when I bought it. the lab says "no" under coolant, so they don't seem to think that is an issue.
As stated in the text in the other thread, the lab wrote down the wrong oil. current fill is Amsoil XL 5w30. I probably won't sample this fill.
[quote=4WD]+1 ... or try that motor on HDEO ...
if I could find a 5w30 easily, I would in a heartbeat. I'm just not sure about using a 5w40 or 10w30 HDEO
Going back to Trop Arctic would be good for diagnosing if the engine really has an accelerating wear problem. Stick with it for at least two changes, and see how the numbers change.
would that be a good comparison? an engine with 195,000 miles vs 115,000?
not sure I'm going to get much out of that.
