Hi all,
I've been reading good things about this new Mobil 1 5w40 and am considering trying it for my next oil change in my Porsche 944. I'm currently running M1 15W50 and am thinking it may be a little on the thick side, but don't want to use a xW30 due to a) factory recommendations and b) it gets HOT here!
So now to my question. I also have a '55 Studebaker coupe with a '63 Stude engine transplanted in it. I've always used Rotella 15W40 for my old stuff but amazingly this engine does not seem to leak oil at all, and I'm going to be doing a cam swap in it anyway at some point in the future (at which point I'll upgrade to a neoprene lip-type front main seal) Since it seems to be so good at retaining oil, I was wondering if the M1 would be a good choice for it as well? t does burn some oil however, at the moment it is sorely in need of valve stem seals and produces some really impressive smoke pulling away from a stop light after a long period of idling. How does the M1 work in an engine that burns a little oil? Better/worse/indifferent compared to a dino oil? I'll probably run dino at least for the first couple hundred miles or so (car was sitting for several years before I got it, so all the whirly bits need to get reacquainted) but after that, since it doesn't seem to leak...?
thanks!
nate
thanks!
nate
