Mobil 1 Euro 0W-40; 1 mile use; MB GLA250 M270 eng
LA (Lower Alabama)
POLARIS LABORATORIES
Lubricant Analysis Report
North America: +1-877-808-3750
Component Information
Component ID: 2015 MERCEDES BENZ E
Secondary ID: GLA250 M270 2.0L I4 GAS TURBO
Component Type: UNLEADED GASOLINE
ENGINE Manufacturer: MERCEDES BENZ
Model: M270
Application: AUTOMOTIVE
Sump Capacity: 6 qt
Sample Information
Lab Number: I-843002
Lab Location: Indianapolis
Data Analyst: JDT
Sampled: 18-Jul-2015
Received: 22-Jul-2015
Completed: 24-Jul-2015
Filter Information
Filter Type: FULLFLOW
Micron Rating: 0
Miscellaneous Information Product Information
Product Manufacturer: MOBIL
Product Name: MOBIL 1 EUROPEAN CAR FORMULA
Viscosity Grade: SAE 40
Comments Flagged data does not indicate an immediate need for maintenance action. Continue to observe the trend and monitor
equipment and fluid conditions. Lube oxidation may be increasing; However; Please submit a new (unused) sample of this fluid
for BASELINE REFERENCE. Viscosity is SLIGHTLY LOW; Lubricant change acknowledged. Your note was taken into
consideration;
Iron ............... 4
Chromium .... 0
Nickel ........... 0
Aluminum ..... 3
Copper ......... 5
Lead ............. 0
Tin ................ 0
Cadmium ...... 0
Silver ............ 0
Vanadium ..... 0
Silicon .......... 10
Sodium ........ 2
Potassium ..... 3
Titanium ........ 0
Molybdenum . 61
Antimony ...... 0
Manganese .. 2
Lithium ......... 0
Boron ........... 171
Magnesium ... 21
Calcium ......... 2741
Barium .......... 2
Phosphorous..850
Zinc .............. 950
Lube Time ......... 1 mi
Unit Time .......... 1952 mi
Lube Change
Lube Added 0 qt
Filter Change NO
Fuel Dilution % .... 0.6 Vol
Soot % ................ < .1 Vol
Water% ................< .1 Vol
Viscosity 100 °C . 12.2 cSt
Base Number ..... 10.2 mg KOH/g
Oxidation ............ 27 abs/cm (flagged at 2/4 - abnormal)
Nitration ............. 8 abs/0.1
