Mobil 1 ESP X4 0W-40
How is it performing for you? Have you done oil analysis? Tks
Nothing really remarkable compared to dealer oil or Liquimoly which I used to run prior to X4. I also try to run Renewable diesel (R99) as much as possible. R99 makes the van run much quieter so can't certainly tell how X4 is working by engine noise alone. Don't plan to perform any analysis since the van gets once a year oil change and only sees 5k-6k miles per year.
Yes, it's not cheap. However, you can order it online on walmart.com at $65 for 6 qts.
https://www.walmart.com/ip/Mobil-1-127918-ESP-X4-0W40-Motor-Oil-6-Quarts/6779217026?classType=REGULAR&from=/search
You can use also Mobil 1 ESP 0W-30 with no worries as well.
https://www.walmart.com/ip/Mobil-1-...6?classType=VARIANT&athbdg=L1600&from=/search
I try not to purchase from third party sellers on amazon or walmart. I purchased mine from summit racing and auto zone.
X3 is discontinued right? Look at the manufacturing date, probably old stock, but still good give it a shake. X4 is awesome performance oil, wish it was on the shelves here in Canada. If you tune or beat the hell out of your car, you can use with confidence.
Edit But not sure its good for extened ocis.
