Originally Posted By: Tornado Red
Can we get back to the main debate?
The original point made was that Mobil 1 High Mileage oil(s) can clean engine deposits better than AutoRx.
Ok. What's to debate? Does a motor oil whose detergency components are measured in parts per thousand remove existing deposits better than a product consisting entirely of lanolin, aliphatic and polyol esters? I've seen absolutely no proof of that. Arguing the point in reverse by deriding the latter product is not proof. The original point, containing nothing meaningful other than manufacturer marketing links, seems little more than a troll.
In my experience, M1 cleans heavy deposits as well as a good HDEO, which is to say barely adequately. Yeah, it cleans . . . a little. And for the price of a crankcase of it, I can buy a bottle of ARX and a case of conventional. But if you want a motor oil for cleaning, use Redline or another ester-based oil.
Every oil protects engines. And every oil leaves behind some deposits, however negligible. Even XOM concedes that M1 only scores 90/100 on their own cleanliness test. With prudent change habits, deposits never reach a meaningful level. And this is true for most oils, including cheap ones, if changed before their chemistry is depleted.
The fact is, most people abuse their lubrication maintainence at some point, so deposits are inevitable in many instances.
If you want to argue that M1 is very good at keeping engines clean, I agree. It's very good motor oil. But if someone is going to claim that it is better than dedicated crankcase cleansers at removing deposits, then present some proof . . . even testimonials.
