Mobil 1 Advanced Full Synthetic 0W-20
San Diego
Today was my first time coming across Mobil 1 Advanced Full Synthetic 0W-20. I was under the impression that Mobil 1 calls their basic 0W-20, AFE...
It was a garage box that my friend had I helped him out with his oil change.
Maybe it was the AFE and Mobil 1 uses different lingo on their garage box?!
tons of marketing you know the shelves are bare fill em up with another product.
Isn't Mobil 1's Advanced Full Synthetic Oil, like Valvoline's Advanced Full Synthetic Oil, their entry level/lowest grade/line of synthetic oil?
NYH.
NYH.
The point that I was trying to make that I had never seen 0w-20 AFS in jugs, when it comes to the jugs, it's AFE
NYH.
This is Mobil's entry level "Full Synthetic oil" which I believe they claim to be good for 7500 miles VS M1 advanced 10,000 miles!!
Valvoline full synthetic starts with its "Advanced" line there is no lower tier from Valvoline
The oil in the OP’s pic and the oil in you your pic are not the same oils.
It’s either Mobil 1 or Mobil. The absence of AFE and Triple Action Formula mean nothing other than a tidier package and possibly a cheaper print. But yeah, to the OP’s point, I can see how it would cause confusion.
For some reason, I can't find that on their website.
NYH.
You mean this ???
Mobil™ Full Synthetic 5w30
Provides guaranteed protection that's 1.5X longer than our conventional and synthetic blend oils
Mobil 1™ 5w30
Helps extend engine life
Outperforms conventional oil​
Formulated for vehicles that require a full synthetic motor oil
Mobil Full Synthetic 5w30 motor oil is formulated for vehicles that require a full synthetic motor oil and vehicles that are upgrading from conventional and synthetic blend oils.
Mobil Full Synthetic 5w30 motor oil meets or exceeds the latest industry requirements for gasoline-powered:
  • Cars
  • Trucks
  • SUVs
Mobil Full Synthetic 5w30 motor oil outperforms conventional oil and provides guaranteed protection that is 1.5X longer than our conventional and synthetic blend oils.* Plus, this motor oil is tested and proven to provide long-lasting protection to help extend engine life.
Recommended for all types of gasoline-powered vehicles
Mobil Full Synthetic 5w30 motor oil is recommended for all types of gasoline-powered vehicles, such as passenger cars, SUVs, light-duty vans and trucks, including models with turbocharged engines.
Always check your owner's manual for the manufacturer's recommended oil viscosity grade, API service classification and any builder approval.
We stand behind our products. Read our Mobil™ limited warranty.
*Guaranteed protection for 7,500 miles between oil changes compared to a guarantee of 5,000 miles or less on Mobil™-branded conventional and synthetic blend motor oils.
Buy Now
Find a service location​
Ask technical
Features and Benefits
Mobil™ Full Synthetic motor oils deliver guaranteed protection that's 1.5 times longer than our conventional and synthetic blend oils. These oils have been tested and proven to provide long lasting protection to help extend engine life.
Key features and potential benefits include:
FeaturesAdvantages and Potential Benefits
Full Synthetic formulation with balanced additive systemOutperforms our conventional oil
Excellent resistance to oil breakdownProven long lasting Protection
Helps prevent sludge/deposit formation and engine wearHelps Extend Engine Life
Maintains oil viscosity even in high operating temperaturesHelps control oil thickening and breakdown
WarrantyLimited Warranty* offers protection for up to 7,500 miles or your vehicle's recommended oil change interval, whichever is longer
Applications
Mobil™ Full Synthetic motor oils are recommended by ExxonMobil for all types of gasoline-powered vehicles, including turbocharged engines, found in passenger cars, SUVs and light-duty vans and trucks.
Specifications and Approvals
This product has the following approvals:0W-205W-205w30
GM dexos1:GEN3 Licensed X
This product is recommended for use in applications requiring:0W-205W-205w30
FORD WSS-M2C945-A X
Ford WSS-M2C930-A X
FORD WSS-M2C946-A X
Ford WSS-M2C929-A X
FORD WSS-M2C947-AX
Ford WSS-M2C947-B1X
GM 6094MX
This product meets or exceeds the requirements of:0W-205W-205w30
API SJXXX
API SLXXX
API SMXXX
API SNXXX
Ford WSS-M2C946-AXXX
API SN PLUS RESOURCE CONSERVINGXXX
API SN Resource ConservingXXX
API SPXXX
API SP Resource ConservingXXX
ILSAC GF-6AXXX
CHRYSLER MS-6395XXX
Ford WSS-M2C945-B1 X
FORD WSS-M2C961-A1 X
FORD WSS-M2C962-A1X
Properties and Specifications
Property0W-205W-205w30
GradeSAE 0W-20SAE 5W-20SAE 5w30
Density @ 15 C, g/ml, ASTM D40520.84740.8508
Density @ 15.6 C, g/ml, ASTM D4052 0.8534
Flash Point, °C, ASTM D92235229
Flash Point, Cleveland Open Cup, °C, ASTM D92 229
Kinematic Viscosity @ 100 C, mm2/s, ASTM D4458.38.410.7
Kinematic Viscosity @ 40 C, mm2/s, ASTM D44544.84664.6
Pour Point, °C, ASTM D97-45-42-45
Health and Safety
Health and Safety recommendations for this product can be found on the Material Safety Data Sheet (MSDS) @ http://www.msds.exxonmobil.com/psims/psims.aspx
Please consult your vehicle manufacturer's manual for information specific to your vehicle.
Quick Links
More Info​
You mean this ???
Mobil 1™ 5w30
  • Cars
  • Trucks
  • SUVs
Buy Now
Ask technical
Applications
GM dexos1:GEN3 LicensedX
FORD WSS-M2C945-AX
Ford WSS-M2C930-AX
FORD WSS-M2C946-AX
Ford WSS-M2C929-AX
FORD WSS-M2C947-AX
Ford WSS-M2C947-B1X
GM 6094MX
API SJXXX
API SLXXX
API SMXXX
API SNXXX
API SPXXX
ILSAC GF-6AXXX
CHRYSLER MS-6395XXX
Ford WSS-M2C945-B1X
FORD WSS-M2C961-A1X
FORD WSS-M2C962-A1X
Density @ 15.6 C, g/ml, ASTM D40520.8534
Flash Point, Cleveland Open Cup, °C, ASTM D92229
Health and Safety
FAQs
Please consult your vehicle manufacturer's manual for information specific to your vehicle.​
Quick Links
More Info​
Yeah, I really couldn't find it.
Thanks, NYH.
Thanks, NYH.
Glad I could help (y) 😎
And honestly this oil and Chevron Havoline ProDS are your BEST bang for your buck oils!!
Bj's and Amazon have run "specials" on the Mobil Full synthetic in the past
  • Like
Reactions: NYH
Do you really think that they beat out Kirkland synthetic for best bang for the buck? When Costco puts it on sale for $15 a jug that is the best bang for the buck in my opinion.
probably the best readily available bang for the buck oil if $$ are at stake would be Quaker State ultimate sold at wall mart for $23.98 per 5qt. jug.
