- Joined
- Jan 18, 2026
- Messages
- 95
killing time in walmart looking at oils and ran into this Mobil 1 5w40. Is this new or old oil formulation. 10k v 15k. whats the difference in base oil?
It is.Hoping 0w40 will be updated as well
there is the particulate filter friendly version, ESP.Mobil 1™ FS 5W-40
i liked that one even though its not available in Europe.
Yes, very well. Not as well as esters, but neither of these oils are known to contain any.does gtl stick to engine better after shutoff?
I would too.I would buy neither, and instead choose Quaker State 5W-40
thanks jag. your link and results are good info to know. very helpful. appreciate your efforts. glad i have stash of old 10w30.In my opinion, unless you live in a very cold climate, Mobil 1 Full Synthetic 5w40 is a slightly better choice than Mobil 1 Full Synthetic 0w40. I believe that based on the similar specifications met and results in this thread:
Link
I would buy neither, and instead choose Quaker State 5W-40 or Pennzoil Platinum 5W-40. If lower SAPS is acceptable to you, I’d also include Mobil 1 ESP 0W-30.
so is Quaker State 5W-40 or motul gen 2 excess , but they are some of the most preferable oils here.FS 5w40 is a downgrade over 0w40. Group III + GTL, no PAO.
yes but cooking oil on the stove is similar to comparing them at the ice luge: totally irrelevant to what 'works.'so is Quaker State 5W-40 or motul gen 2 excess , but they are some of the most preferable oils here.
remember final product matters at the end.if it works then its good.
at the end of the day thats all that matters.yes but cooking oil on the stove is similar to comparing them at the ice luge: totally irrelevant to what 'works.'
best-selling is also not relevant to what 'works.' as you say, "most drivers dont judge by recipy,they dont bother to know."at the end of the day thats all that matters.
since we are speaking with cooking terms, one thing is recipy ,the other thing is the result.
repsol says is using PAO for their recipy ,specs are good ,result is mediocre.
Quaker State 5W-40 or motul gen 2 excess dont but we have testimonials they work better than other PAO oils.
shell helix 5-40 here in europe is one of the most good selling oils.if it didnt work they wouldnt use it.
and its the same as Quaker State 5W-40.
so yes if it sells ,it works,if it works then its a good oil ,no matter what recipy.this is for us here that split hairs.
Your viewpoint that you keep stating warrants a response from me. I do not boil oils on a stove. I do volatility measurements and state the approximate temperature for each test. The temperature is well below the boiling point. After doing the volatility tests, I continue the test without weighing the oils. The purpose is to continue oxidizing the oils and observations are made about deposit and insolubles formation. The test is obviously not completely representative of what oils experience inside of an engine, however oils in my tests and in engines both experience oxidation.I was comparing Mobil 1 Full Synthetic 5w40 to 0w40 FS. In which case I do not believe there is any serious debate, except in the "which oil boils more on the stove" test. 0w40 FS is the clear flagship product for Mobil 1 Euro full saps oils.
Or generally better base stocks that have superior oxidation and sludge resistance.I think 0W-40 oils are popular with Euro automakers because it is suitable for use in almost any location on Earth that cars are driven. 0W-40 also favors fuel economy compared to a similarly-formulated 5W-40 because of generally having lower permanent and temporary shear stability. Oils are full of pros and cons. An oil that is superior in one use case and criteria one most cares about often is inferior in another.
