Mobil 1 5w-50 and 0w-40 NOAK's on NZ site
Al,
If I was a betting man, I'd say the 5w-50 was available in New Zealand ...
TooSlick
For some reason this page http://www.mobil.co.nz/pr_guide/start_pg.html
lists the 0w40 with slightly different specs.
Typical Properties
code:
Mobil 1 0W-40
Product Code 97E494
Test Method
SAE Grade 0W-40
Viscosity ASTM D445
cSt at 40oC 71
cSt at 100oC 13.5
Viscosity Index ASTM D2270 196
Viscosity after shear,
cSt at 100oC 13.4
High Temperature/ ASTM D4683
High Shear (HTHS)
Viscosity
(150oC/106s-1)cP 3.55
CCS Viscosity ASTM D5293
cP at -30oC 3000
MRV Viscosity/
Yield Stress
cP/Pa at -40oC 16000/
cP/Pa at -35oC 9000/
Noack Volatility CEC
1 hour at 250oC L-40-T87
Loss wt % 10.5
Flash Point, oC ASTM D92 230
Pour Point, oC ASTM D97 pre>
I just figured out that the specs I posted above are from July 1996.
The links in the first post say 2002.
Sorry.
[ April 26, 2003, 11:59 AM: Message edited by: jjbula ]
