Blackstone Lab report:
Sample; 6/29/06 Rpt; 7/14/06
(Comment)
"No problems showed up in the second sample from your Ion. All wear read close to averages
for this type of engine, which is a very good indication of normal wearing parts and careful operation. The universal averages show normal wear after 4000 miles on the oil. Insolubles (oil oxidation due to heat, use and blow-by) were low at 0.2%, showing good oil filtration. No fuel dilution or anti-freeze was found. Silicon was normal showing good air filtration. The TBN was 3.4, okay - 1.0 is low. Try 7000 miles for next sample and check back to see the results. Nice engine!"
Report: Universal
Averages:
ALUMINUM 3 /3
CHROMIUM 0 /1
IRON 10 /14
COPPER 7 /4
LEAD 0 /4
TIN 1 /1
MOLYBDENUM 79 /64
NICKEL 0 /0
MANGANESE 1 /0
SILVER 0 /0
TITANIUM 0 /0
POTASSIUM 3 /1
BORON 44 /50
SILICON 7 /9
SODIUM 3 /8
CALCIUM 2495 /2247
MAGNESIUM 11 /82
PHOSPHORUS 640 /728
ZINC 739 /856
BARIUM 0 /0
No water
No antifreeze
Test: Tested:
Sus Viscosity @210F
(55-62) /58.5
Flash Point >365 /400
Fuel
Insolubles <0.2
(Comment)
Report: Universal
Averages:
ALUMINUM 3 /3
CHROMIUM 0 /1
IRON 10 /14
COPPER 7 /4
LEAD 0 /4
TIN 1 /1
MOLYBDENUM 79 /64
NICKEL 0 /0
MANGANESE 1 /0
SILVER 0 /0
TITANIUM 0 /0
POTASSIUM 3 /1
BORON 44 /50
SILICON 7 /9
SODIUM 3 /8
CALCIUM 2495 /2247
MAGNESIUM 11 /82
PHOSPHORUS 640 /728
ZINC 739 /856
BARIUM 0 /0
No water
No antifreeze
Test: Tested:
Sus Viscosity @210F
(55-62) /58.5
Fuel
Insolubles <0.2
