Mobil 1 15w50 or 0W30?
Spring HIll
Welcome to the board!
With little statistical backing, I can only shoot from the hip on this engine, but I'd choose Mobil 1 0w-40 or the 5w-40 derivative "Truck & SUV" product. A bit thicker than the standard 30 weight products and provide excellent protection.
Even as a fan of Mobil 1 15w-50, I think it may be a bit too thick for your new truck.
So far, I understand the logic except for the "too thick for my engine".
How can it be too thick?
When I look at the specs on 15w-50, it seems to my untrained eye like the specs are better...please explain.
Certain engines perform better with certain viscosity oils. For example, GM's 4.8/5.3L V8's enjoy a thick 30w or lighter 40w oil.
Check out the Used Oil Analysis section, namely this UOA:
http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;f=3;t=001810#000000
This is one engine where a 30 weight oil might be best. There's only a small amount of used oil analysis on this board for this engine, so it's difficult to tell for sure.
Why not try a good synthetic 30 weight (such as Mobil 1 10w30) and perform an oil analysis? The more data we have on this new engine, the better!
in a Nissan Titan in San Antonio, Tx. I pull a trailer and cargo quite a lot that brings it to it's max GVWR of 14,600 lbs. It's HOT down here about 9 months out of the year...
I bought it with 5k miles on it. I changed the oil immediately to Mobil 1 15W-50 and have put about 2.5K on it since. I also changed the rear dif oil to Mobil 1 also.
I'm new to this board, so please be gentle. I thought I knew oil until I started reading and searching on this forum.
Please "teach" me with your answers, and keep the techie lingo to a level that an old gear head can understand!
Thanks in Advance...
If your want total protection under extreme conditions, use whatever grade your owners manual recommends but use a synthetic like Mobil 1. This is especially true in the rear diff but watch out for Posi-trac and the special additive required when replacing the fluid. I personally would not use 15w-50 unless your book has that rangem regardless of being Texas and towing.
