- Joined
- Jan 29, 2022
- Messages
- 243
The vehicle is my 2001 Chevy Blazer 4x4 with the 4.3 Vortec. The truck has about 120,000 miles as of Oct 20.
So the first picture shows the inside of the oil filter adapter area before using Mobil 1 ESP 0w-30. Taken on June 13, 2025, after draining Valvoline Restore and Protect. But the inside still looked the exact same, after Valvoline Restore and Protect. Its always looked just like this since 3 years ago.
As you can see there was lots of varnish and what almost looked like stuck on sludge in some areas. It’s been just like this since I got the truck almost 3 years ago. This truck has seen nothing but regular API SP spec 5w30 oil changes, and maybe 2 or 3 oil changes with Mobil 1 Full Synthetic0w40 in 2024.
Now the second picture is after running Mobil 1 ESP 0w30 for about 5500 miles, from June 13, 2025 through October 20, 2025.
The difference actually surprised me yesterday when I took the filter off. Mobil 1 ESP 0w-30 did such a good job with cleaning out a lot of the varnish and sludge that other API SP spec oils such as Valvoline Restore and Protect, Pennzoil, Rotella T6 MV, and others didn’t.
I ended up putting in Pennzoil Platinum HM 5w30 API SQ in the truck this time, because I got 5 quarts for $22, and did not realize ESP did this good until I bought the pennzoil and did the oil change. If I knew I probably would have got the ESP, but maybe on the next oil change.
Pretty impressed with ESP! ESP 0w20 is going in my 2016 Lexus ES350 when it needs an oil change. I’m sold.
