My parents have two vehicles with these engines; a 2001 S10 Truck and a 2004 S10 Blazer.Im guessing the previous owner got the oil changed about every 7500 miles at a shop, which is what GM recommends in the owners manual. I know this from looking at the carfax report, but who knows if it’s legit. Don’t know what oil was used, but it’s gotta be some off the shelf API type of oil. The 7500 mile OCI from the previous owner clearly didn’t keep the engine clean enough. The 4.3 vortecs are known to be pretty easy on oils, even though it only holds 4.5 quarts in the sump.
Both use “synthetic blend” level oils at a quick lube every 5k miles; ignoring the 6 months for some reason ?
So, when I asked my dad if either engine uses oil, apparently he hadn’t been checking. Guess what? The blazer was low 1 Quart!
He doesn’t know how long it’s done this and the issue was he was not changing it at 6 months; waited on miles instead despite reaching the time limits most put on bulk/entry level synthetics (which a syn blend he has latched onto for years due to half truths from the 1990s but I can’t blame him)…
The vehicles are mostly short tripped in a small town. Sometimes taken on longer trips.
Short tripping is one of the worst things you can do for an oil if you want to go past minimum maintenance timeframes/mileage (6 month/5k whatever comes first)
With those results, I recommended Valvoline Restore and Protect, but he is set in his ways. Sounded open to the idea of topping off with said oil. I doubt it would do much that diluted though.
The truck is driven less and seems less effected by less frequent short trips and has less total miles.
