No it shows it absolutely acceptable and allowedAnd with that, 0W20 becomes a thick.
Yes I undestand, it was a funny/ha haNo it shows it absolutely acceptable and allowed
Remember Dr. T?When this site first started, a lot of people considered 5w30 to be thin and 20w50 to be thick. These days 5w30 seems to be almost what some would consider as thick. Maybe in 20 more years 0w16 will be considered as thick![]()
Remember Dr. T?![]()
cant wait for the 0w-30When this site first started, a lot of people considered 5w30 to be thin and 20w50 to be thick. These days 5w30 seems to be almost what some would consider as thick. Maybe in 20 more years 0w16 will be considered as thick![]()
The obligatory LM post…
I pity the fool … wait, I might be confusedRemember Dr. T?![]()
I see Royal Purple has a 0w-16 oil, this maybe a good oil to consider also.I might as well be using 0W-8 in a 2024 Rav4 Prime XSE.
2 UOA at 4k and 8k miles revealed both Pennzoil Platinum 0w-16 and Eneos 0w-16 sheared below and out of grade. Both had normal fuel dilution with Blackstone and Speediagnostix.
I'm now running Idemitsu IFG7 0w-16 and will get another UOA. Afterthat I will try Amsoil Hybrid 0w-16.
The search continues for the most shear stable 0w-16.......
Correct. But never seenndirtybpol in thereGreat as an engine flush!
The fears. Oil is oil. Thin or thick. What matters are the added compounds and the materials werd it is going to be used in... mhoFor Toyota it is binary choice when it comes to fuel dilution: why having bit of gas in oil, when you can have bit of oil in the gas.
So base attributes such as HT/HS, cold weather performance, VI and oxidation resistance don’t matter?The fears. Oil is oil. Thin or thick. What matters are the added compounds and the materials werd it is going to be used in... mho
Sure. I did not write they don't or do.So base attributes such as HT/HS, cold weather performance, VI and oxidation resistance don’t matter?
Jaso GLV-2Why should one doubt that a 0W-8 is appropriate?
That is the same argument as GLV-1. I know about this already. What are you trying to tell me?Jaso GLV-2
https://www.sae.org/publications/technical-papers/content/2025-01-8468/
Paper not published yet.
That would be 0w20I might as well be using 0W-8 in a 2024 Rav4 Prime XSE.
You said it yourself. It’s recommended.Sure. I did not write they don't or do.
Look engine manufacturers spend millions every year on each engine they design testing everything. Oil off course. Why should one doubt that a 0W-8 is appropriate? Then again the service manuals and user manuals do state that we can go all the way up to even 5W-30. Imho I think we should keep to the recommended. Hybrids run mostly cooler than most other cars. If one uses it to race around then perhaps would be better to go into a higher grade. What I read all the time is this rhetoric about w8 being like water.
Run you car on the highway at 130 for about a hour. Then stop and check the oil. If that's not viscous enough I don't know.
