I have a 1987 Mercruiser 350 in my 23 ft ski boat and I am thinking about using Mobil 1 0w-40fs as I have it in all my older Toyotas and seems like a great oil overall. Would this be a good choice with enough ZDDP etc for this application?
I agree 100%. I have never run the crappy mercruiser 25w-40 in any marine motors(I’ve built quite a few including a 700hp BBC). A very outdated recommendation IMO. Boat in question is stored inside and on sees lake duty here in Arizona. Has freshwater cooling.Though M1 FS 0W-40 is formulated on the edge of the 30/40 grade boundary, and often shears out of grade slightly, it is actually quite stout for a common shelf oil. I'd trust it before I would any common conventional or syn-blend 25W-40.
You have to think, FC-W is a rather pathetic spec. It allows up to 50 ml of foam with 10 minutes of settle time, the minimum HTHS is just 3.3 cP, an SAE 40 can shear by 30% and still pass, and allows up to 22% Noack volatility. The only thing somewhat stringent about it is the saltwater rust prevention test which I don't think matters much to the OP living in Arizona.
Mercruiser actually didnt offer roller small blocks until the later 90’s. The 87 block has the bosses to covert to roller but my engine is a factory flat tappet black motor.Chevy started using roller tappets in 1987. Would that not be the same for the Chevy - Mercruiser 350 Chevy engine. Maybe I’ve missed something. If that’s truly the case use whatever will pour in it. If it’s still flat tappet I’d go with a healthier dose of zinc - oil.
There was never a roller Windsor used in marine engines. I’ve been inside several GT40 PCMs myself. The blocks were roller capable but ran flat tappets (like the 351 in the lightning truck).I'm a HUGE fan of M1 0W-40 and have used it in a ton of older engines for the same reasons as you. However, I'm running Delvac 1 5W-40 in our 351W GT40 due to it being a bit heavier and PCM spec'ing a similar viscosity to Mercruiser, which is a heavier xW-40. I don't need the added phosphorous, since the engine is roller.
