I've run 'em both. No UOAs, but both are very good performers with good base oils.
The M1 starts at a 40 but is quick to shear down (sometimes way down) into the 30s. I can't say I agree with Buster that it's a good oil design, as some engines like a stable 40 and that's its advertised vis.
IIRC, one of the high priests here once opined that it meets test sequences by oxidizing back out to a 40 by the end of the test interval. Very creative. In a high stress environment, it is not necessarily a long interval oil unless you've got sufficient sump capacity. One UOA from a fellow R owner several years ago showed it pretty much used up by 4k.
GC starts at a near 40 and seems to hold its vis, however, with some thickening under heavier thermal stresses (tracking).
If you offered me a case of either, I'd take the GC. But I wouldn't be upset with the M1. Delvac 1 is still one of my favorites, and I'd take it over the 0W-40, too.
At this level, you are talking nuances among caviar. None of them will hurt an engine under sane usage.
