I already use 5w30 in my '22Limited (calls for 0W-20) and 5w30 For my Forester XT (calls for 5w30).
We'll see how the used oil analysis compare.
SP or SN Mobil 1 0W-40?I already use 5w30 in my '22Limited (calls for 0W-20) and 5w30 For my Forester XT (calls for 5w30).
SPSP or SN Mobil 1 0W-40?
The oil will be left in there at least 10K miles for both vehicles.What do you expect to see in a used oil analysis here? The viscosity will be a bit higher even with some fuel, otherwise there will be zero difference w/r to wear metals.
So TBN and viscosity checks.SP
Was this an inspiration?The oil will be left in there at least 10K miles for both vehicles.
I take enough used oil analysis that I don't worry about. I would actually like them to challenge it. I have the time and knowledge.Curious why you would do 10k OCI with a vehicle still under factory warranty?
lol...no
10k in a Turbo Subaru??? I would not recommend it, but you do you, boo.SP
the 22 is GDI10k in a Turbo Subaru??? I would not recommend it, but you do you, boo.
In many thousands of UOA I have yet to see an issue with tbnSo TBN and viscosity checks.
Which version of Mobil 1 0W-40/5W-40 is the famous one for cleaning up a sludged / varnished engine (possibly due to high Ester content), as there are many different Mobil 1 formulations?
