Mobil 1 0W-40 Base Oils Revealed
JAG
Fredericksburg, VA
It's amazing what is posted on the internet.
The paper is dated 2006 and is titled: "IN SITU LUBRICANT DEGRADATION IN ANTARCTIC MARINE SEDIMENTS. 1. SHORT-TERM CHANGES"
http://www.setacjournals.org/perlserv/?request=get-document&doi=10.1897/05-015R.1&ct=1
The purpose of this study was ecological in nature. They measured/identified the base oils in two oils, Mobil 1 0W-40 and Fuchs Titan GT1. I'll just highlight the M1 findings.
Quote:
The unused lubricant was found to contain a complex mixture of alpha olefins, several specific alkyl diphenylamines, a complex mix of C26H40 alkyl naphthalenes, 4,4′-methylene-bis(2,6-di-tert-butylphenol), and a range of alkanoate esters of 1,1,1-tris(hydroxymethyl)propane (1,1,1-TMP) (Fig. 2).
If that's Greek to you, that means multiple PAO base oils, multiple alkylated napthalenes (Group V oil), and multiple TMP esters.
The butylphenol mentioned in the quote is an antioxidant, not a base oil.
That's a very nice base oil mixture which is no surprise because the specs that this oil meets are some of the toughest to meet. So there we have it, Mobil 1 0W-40 uses a Group IV/V mixture.
You may have missed the reference to "Mobil 1 (0W/40) trisynthetic lubricant (Exxon Mobil, Irving, TX, USA)".
Tri-Syn was a couple of iterations ago in the Mobil 1 line-up.
Proof that you can cold cache oil on the sea floor for later reclamation.
(imagine some less cerebral type ..late teens ..mid 20's ..)
Well, I'll bet Amsoil would have retained even the additive packs in the same test on a one year SCI (sediment change interval).
Good alternate source there, JAG. They're not selling motor oil ..or even cars.
It is an older article but they were on Supersyn by then weren't they? Anyhow that is some pretty tightly controlled stuff, blended at a certain group of cars. Probably not changed much.
how's this stuff Group V oil? if the used oil analysis posted over the years show this 0w-40 grade shears? or am I missing something?
What on earth are you talking about?
Does anyone take the time to search and read prior threads anymore?
That is nice...for 3 years ago.
And doesn't help me when I run a 5w-20 or 30........
I searched the document and saw no mention of the oil being the Tri-Synthetic version. I know that that version preceded the current Supersyn version and that its base oil mix was PAO, ester, alkylated napthalene mix, hence the name. Is that what your point is? Or did I miss that the oil being tested here bis the Tri-Synthetic version?
nope, I can't keep up with guys who have 20k posts.
The search function sucks so I quit using it years ago.
The base oil mix was stated above and it is not just Group V. Oils permanently shear when viscosity index improvers break apart.
No matter what the base stocks, a 0W40 still requires Viscosity Index Improvers, and can still shear.
If y'all have learned one thing on BITOG, it's that base oils alone do not determine performance. Base oils need to be formulated with additives which enhance the properties. It is these additives that define many of the properties we like in a good oil. Focus on base oil composition alone is an interesting exercise.
+1
Jag 8th paragraph down from Introduction you will find this reference.
The aim of the present study was to investigate the in situ degradation of a Mobil 1 (0W/40) trisynthetic lubricant (Exxon Mobil, Irving, TX, USA),
Ken
Originally Posted By: BrianWC
Good work JAG! Those 4 qts on my shelf are looking a bit nicer!
yes nice find great oil the 4 cases on my shelf look even better always knew ow40 was great oil,an oil still can protect well if it shears.
Mobil 1 0W-40 is on the very low end of 40.
Slight shearing and it measures as a high 30.
Folks don't do VOAs to compare with used oil analysis and conclude it's shearing more than it is.
[I searched the document and saw no mention of the oil being the Tri-Synthetic version.
Once again "Mobil 1 (0W/40) trisynthetic lubricant".
That is a direct quote.
