So if the used oil analysis reports showed additional wear or a problem then you'd agree with them? You've obviously searched the www. high and low to try and find fault with MMO, and this was all you could find? I'd think in over 85 years if it were ruining engines we'd know, There are probably thousands if not tens of thousands of people running in their sump year round each and every OCI. A know a few personally that have done so for decades, with squeaky clean engines with very high miles on them.
I was looking for an additive (reasonably priced) to add to diesel fuel since the VP44 in my pickup needs lubrication and its not a guarantee that all diesel fuel has the proper lubrication additives for my engine given that its all ULSD now. So I came across this set of test results and decided to go with 2 cycle oil bought by the gallon at Walmart. However I got to thinking that the MMO test result is also valid for engine oil use of MMO.
As a cleaner, I would go with Kreen of AutoRx.
