MMO in every fill up?
if you buy MMO in the one gal jug, ie TSC, when the weather gets cold the plastic will break and spill the oil. go get a 1 gal gas can, and put the MMO in it.
I mix 5oz bottles I keep in each car for fill ups, I use 3oz MMO+2oz Chevron Techron. I can tell you my cars have never run better-been at this for nearly 3 years and there is no downside. MMO in gallons is cheap, Chevron Techron on BOGO is also if not cheap at least affordable. Bottom line-it works for me.
I do something very similar to mgm13. I use an old 1 qt. Stabil bottle to mix 26 oz. MMO and 6 oz. Techron Plus. This is approximately 80% MMO and 20% Techron Plus.
I use this at the rate of 1/2 oz. per gallon of gas. This gives me a dosage of 0.4 oz. per gallon of MMO (The recommended dosage.) and 0.1 oz. per gallon of Techron. (Approximately the rate that is in Chevron gas.)
I use this in all my vehicles. I've only been doing this for about 6-7 months, but it seems to be working very well.
to get mmo lubed in the intake manifold i use http://www.ampcolubes.com/ ST400
Plastic 1 quart container. Appropriate for all applications, modern vehicles and classics where the use of a glass container is a concern. About 2 inches taller than the ST100 kit.
check it out.
