Originally Posted By: bourne
Originally Posted By: Danh
Not sure what the purpose would be. The risk unique to DI engines is deposits on the intake side of the intake valve, but MMO won't touch this area. If you check your owner's manual I expect you'll find a statement saying additives to gas/oil are not recommended or necessary.
Injectors in DI engines are much more precise and operate under much higher pressure than traditional injectors; I don't know what MMO might do to them, but I'd avoid trying to find out.
The deposit problem isnt the biggest concern for me. It has been shown that DI engines CAN operate without ridiculous amounts of deposits. Seems a few manufacturers are having more issues with this than some others. I havent heard/read anything from Mazda having this issue yet. Fingers crossed.
I am primarily concerned with the lubricating properties of MMO. As UCL and for keeping the fuel system lubricated against the ethanol content in gasoline. I am also very interested if it has any effect on the injectors since, like you mentioned, they operate at the MUCH higher pressure vs injectors in a port injected engine. Also since its supposed to produce a "cleaner" burn, would this aid unintentionally in lesser deposits ?
Understand that while MMO may have some cleaning properties, it has POOR lubricating properties. When MMO was added to diesel fuel and then run through the industry standard HFRR test it made the lubricity of diesel fuel worse than diesel fuel alone. Why anyone would add it to gas or diesel fuel to help with lubricity is beyond me. I have posted links to these tests before.
