My 2017 VW GTI has 120k miles on it. It went in for service to diagnose a loud rattle noise near the upper part of the engine that was originally thought to be due to a failed cam adjuster magnet. When replacing the magnets didn't resolve the issue, the valve cover was pulled and the cam sprocket was found to be loose/worn which seems to be causing the noise. Incidentally the mechanic noticed that the camshafts have some scoring on them with associated scoring on the journals/head and valve cover where the cams sit. The car had the timing chain done 6 months prior to when this noise developed. Two weeks prior to the noise, I had an oil change/dsg fluid change.
I have owned the car since new, its not tuned or tracked and AFAIK the car has never been run low on oil. The low oil level or pressure light hasn't ever been on and sporadic checks of the dipstick show little to no level decrease between oil changes. I followed the 1 yr/10k VW recommended synthetic oil change interval with the VW 5w40 oil (502?). Since no other cause has been identified, the mechanic is suggesting the 10k oil change interval over time caused this wear to develop. Unfortunately I hadn't had a chance to do a UOA on this car before the problem developed.
Has anyone else run into this? Thoughts on the cause?
