Some feel the M1 10w30 is a bit on the thin side at 10 cSt, so they add a quart of M1 15w50 to thicken it up.
Take Maxlife. 10w30 is 10.5 cSt. 10w40 is 13.5 cSt. Maybe your car seems to run better on something in between (does it? That is a whole different topic for a different thread). Mix them 50/50 and you will get someting a bit below 12 cSt, so you just made a thick 10w30. You could use a different oil like Citgo Ultralife 10w30 which already is about 12 cSt, but maybe you like Valvoline, or maybe you have a bunch of Valvoline on hand.
You could even thicken up the base oil by adding a quart of straight 30 to the rest 10w30. That one would probably not be wise in winter up north though.
I think you are fairly safe if you mix of the same brand and probably better the closer the viscosities, i.e., 10w30 with 10w40 instead of 5w20 with 20w50. Just a guess.
And sometimes we mix because we just can't help playing with oil!
Some like to mix synthetic in with dino or true synthetic in with fake synthetic, etc. Make your own blend instead of guessing what percent synthetic is in the pre-bottled blend.
[ February 22, 2005, 03:25 PM: Message edited by: TallPaul ]
