Thanks all and I didn't mean to make something easy more than complex than needed. The answer, from I can discern, is that mixing 2 different weight viscosities with relatively 'small' and 'large' size oil molecules is not the same as starting out with medium size ones. Thus, mixing some 15w-30 Mobil 1 with some 5w-30 Mobil 1 is not the same as if Mobil formulated the 5w-30 to be at the mid 30 wt viscosity range (versus ligher end) to beign with.
As to Mobil 1 0w-40, I can't use it. My car, which is new and under warranty, specs either 5w-30 or 10w-30 so I'll just have to be content with a xxw-30 that is on the thin side of the 30 wt viscosity range or switch to amsoil 5w-30 (I would like this oil more if it had some moly in it) or redline 5w-30 and ignore their non API status...the later 2 oils have a high temp vis of 11.1 and 10.9 against Mobil 1's 9.7/9.8 for their 5w/10w-30.
As most of us tend to do, looking for the ideal oil to use in my application. Thanks again.
