Yesterday‘s thread on the exact same subject:
https://bobistheoilguy.com/forums/threads/mixing-oil-to-top-off.348968/
All API licenses include a requirement to pass ASTM D6922.This is my sense, too.
Why would there be issues? Other than maybe the blend could be too thin. People are so market driven.Any issues on mixing Shell Rotella Gas Truck 0w20 with Shell RGT 5w30 in equal amounts? I have a large amount of 0w20, prefer to run 5w30, although Ford recommends 5w20 for my 2002 F350 6.8L V10 with 200k miles. This truck sits a lot, but when it is run it typically has a 10k gooseneck behind it.View attachment 81126View attachment 81127
People tend to let their opinions get in the way of facts.Isn't part of the API certification that it can be mixed with another oil of the same API class oil without negative affects?
What is the difference in the oil additive packages. No not the snake oil type additive packages. Here isI used to think it was ok to mix different brands which have different add packs, base stocks, etc, until I talked to the chemists in HPL's lab. When I asked them this question, they said no, do not mix different formulations together and think everything will be ok in the crankcase. The only way you can possibly know if the oils will work well together is to test the frankenbrew in the lab. The main problem they see if foaming. They have seen a perfectly functioning engine oil that will foam like nobody's business when just a small amount of another additive is added. They have even see oil foam when an anti-foam agent is added! Additive clash is real and I needed no more convincing not to mix oils.
How Amsoil can make the claim that "AMSOIL Signature Series Synthetic Motor Oil is compatible with other conventional and synthetic motor oils."What is the difference in the oil additive packages. No not the snake oil type additive packages. Here is
Amsoil's Signature Series cut and paste from their data sheets . Is Amsoil that special to be able to be compatible and other major producers or bottlers aren't ?
COMPATIBILITY
with other conventional and synthetic motor oils. Mixing other oils
with AMSOIL motor oils, however, will shorten the oil’s life expectancy and reduce its performance benefits. AMSOIL does not support
extended drain intervals where oils have been mixed.
Aftermarket oil additives are not recommended for use with
AMSOIL synthetic motor oils.
TECHNICAL SERVICES
If a 20-grade is permitted, how could any mixture of a 20 and 30-grade be too thin?Why would there be issues? Other than maybe the blend could be too thin. People are so market driven.
I think we need to get a better understanding of ASTM D6922 and what that test entails. If what some of the others are staying is correct, then mixing oils should not result in the foaming issues you described/witnessed. If it does, is it possible that this is due to the experiment being conducted with non-API approved oils?How Amsoil can make the claim that "AMSOIL Signature Series Synthetic Motor Oil is compatible with other conventional and synthetic motor oils."
How could they possibly know how the frankenbrew will perform? How could they possibly know if it will foam?
Why keep changing brands? Find an oil you like and stick with it.My curiosity is because I'll end up with a bunch of containers with a quart or so of oil left in them from different brands.
There is this thing called price - and staying cost-competitive for your audience. If you don't do it, your competitors will.Why keep changing brands? Find an oil you like and stick with it.
What!? As an end-user you have competitors? Or are you in a situation where you're supplying oil to customers?There is this thing called price - and staying cost-competitive for your audience. If you don't do it, your competitors will.
IMO, this statement is far too vague, rendering it meaningless. You simply cannot test everything, or even a meaningful sample.I used to think it was ok to mix different brands which have different add packs, base stocks, etc, until I talked to the chemists in HPL's lab. When I asked them this question, they said no, do not mix different formulations together and think everything will be ok in the crankcase. The only way you can possibly know if the oils will work well together is to test the frankenbrew in the lab. The main problem they see if foaming. They have seen a perfectly functioning engine oil that will foam like nobody's business when just a small amount of another additive is added. They have even see oil foam when an anti-foam agent is added! Additive clash is real and I needed no more convincing not to mix oils.
I guess I was speaking from a business position.What!? As an end-user you have competitors? Or are you in a situation where you're supplying oil to customers?
And what if your car is overdue for a service and that particuliar oil is not found at Walmart?I guess I was speaking from a business position.
But even for an end user, price is always a factor. If you are trying to manage your costs, changing brands is inevitable in order to keep up with sales.
