Mixing 0w20 with 0w40?
Clarence NY
Hi, My 14 Silverado 5.3 calls for 8qts for a oil change with filter. The
recommended weight by GM is 0w20. I have a few quarts of 0w40.
Can I safely mix these two weights? Like 6 qts 0w20 to 2 qts 0w40?
I only put on about a 1000 miles a year on this truck,change oil every
year.
Thanks
year.
Thanks
You will find out if you do this, do you have AFM or VVT on this Vehicle?
Unless it's Pennzoil Ultra Platinum 0W40 being mixed with 0W20 Pennzoil, or Mobil 1 ESP 0w20 being mixed with Mobil 1 ESP 0w40, I wouldn't recommend mixing most 0W20 products with 0W40 as 0W40 with the exception of Pennzoil Ultra Platium 0w40 are High SAPS or Mid-SAPS Euro oils that likely have different additive chemistry than almost off the shelf 0W20, while they are miscible the final product will likely perform worse mixed than when used separately.
That will make no difference whatsoever.
Depends on ECU programming, thermostat, etc. Once I went to a 180F thermostat and deleted the grille shutters in the RAM 1500, the HEMI became more sensitive to viscosity in terms of VVT and MDS actuation. That's because, as @OVERKILL said, I doubled down on MOFT. A 2~4cSt difference in cSt at operating temperature won't make a difference, you're right. But when your new operating temperature is around 185F to 190F down from 225F, then a 10cSt will make a difference and you'll see it manifest itself in the fuel economy taking a dip, mostly. Realistically, even running ILSAC 5w30 in that HEMI, I'm losing around 2 MPG on average. Happiest I've seen that engine was on 0/5W-20 with the cold thermostat. I think that engine would be a very good candidate for the HPL "Overkill" 0W-20.
It all goes down to the temperature-viscosity relationship.
However, you're absolutely right: in a stock engine, it won't make a difference.
[Edit]
I also change the intake with the one from the 3.0 EcoDiesel, so now it can suck twice as much air as it did before. This resulted in better low-end torque. In practice this means that it drives like a limo now, even when towing my empty trailer that weighs ~1000lbs.
Every vehicle is its own chemistry experiment. For the sake of (our) scientific curiosity,
images
Using Mobil 1 0w20 & 0w40, I do it in a Pentastar V6 Durango at 5:1 ratio.
Comes out to be 48.5@40c/9.4@100c pretty much a thick 20 or very thin 30 weight.
year.
Thanks
So mixing those in that ratio creates 00W25? :unsure:
[Edit]
Why did you swap to a colder thermostat?
