OVERKILL
$100 Site Donor 2021
The API ensures that oils of the same API spec are compatible with each. If mid-way through your OCI you’re down a quart of oil and you don’t know what brand of oil the shop used, do you really think you’re causing harm by pouring a quart of oil that’s a different brand? I mean come on now. I’ve never heard of any motor oil company say you can’t mix with other brands. The only thing I’ve read from motor oil companies remotely regarding this is if you are using an extended mileage formula. Extended mileage formulations such as, Mobil 1 extended performance, Castrol Edge extended performance, and Amsoil Signature Series, cannot guarantee the long drain interval if topping off with a different motor oil.
Which brings me to another point. Pennzoil has a new oil called Pennzoil Top Off Oil. It was mentioned here once and I saw it on the Shell product guide about a week ago. Do you think Pennzoil is going to market something that is going to cause some sort of chemical imbalance?
No they don't, please see my reply above. The miscibility standard appears to be widely mischaracterized.
ASTM D6922, from here: https://www.api.org/-/media/Files/C...hash=C16D3A3F94222F002EB3A1C9AC45BE19AC52ECA6
Denotes:
- Shall remain homogenous and, when mixed with ASTM reference oils, shall remain miscible:
That's all it promises.
The test:
ASTM D6922
Apparatus for the determination of homogeneity and miscibility in automotive engine oils. It is important that engine oils from different manufacturers be homogenous and miscible with each other, because operators of automotive engines often do not have prior knowledge of the manufacture of the oil that is currently used in their application, and engine failure can occur if oils are combined that do not stay homogenous and function properly. For this test method visual color determinations and observations are made on an undiluted test oil specimen, along with six blends of the same test oil that have been combined with specific reference oils at room temperature after the samples have been preheated to 46°C in a TC16 liquid bath. Then manually (as this is the referee method), the pour point of the samples is determined using single and adjustable Tamson TLC40-14(s) and/or TLC80-14(s).
They aren't mixing M1 EP 0w-20 with Valvoline Maxlife 10w-30 and confirming the performance characteristics, simply whether, when mixed with the six reference oils, whether the product separates or the pour point changes dramatically. That's it.
