Originally Posted By: pandus13
Originally Posted By: BlueOvalFitter
Originally Posted By: CincyDavid
We're building a new house, and the builder uses Whirlpool appliances. We'll still need a fridge and washer & dryer. Does it bug you to have appliances from different manufacturers? I've had good luck with Whirlpool previously, but I'm not set on the fridge matching the stove and dishwasher. The washer & dryer are at the opposite end of the house so I don't suppose that matters at all.
Thoughts?
In the end it's all what matters to you.
Wait a minute BOF...
forget the shinny appliances and tell us from your experience as a master plumber what would count on a builder house.
Merci beaucoup Mon Ami!
What matters is if you let the contractor pick your appliances they are only going to choose an appliance that will last at least 1 year, which is the normal warranty on a house. After that, you're on your own. You can also save money and NOT have the contractor supply your appliances. You then should choose appliances by their longevity, not the lowest price.
When I was helping my buddy on the weekends do a fixture set, he chose PRICE PFISTER, KOHLER, MOEN, and DELTA faucets. Badger Insinkerator garbage disposals, Maytag or Whirlpool dish washers, and Whirlpool and Kennmore washers and dryers. Fridges, LG and Whirlpool. If you want a cast iron tub, I would ONLY recommend a KOHLER. Toilets, KOHLER, AMERICAN STANDARD, and BRIGGS. Tub and shower valve, DELTA or MOEN. Same with the lav. Also, buy elongated toilets. Your arse will thank you. If your toilet comes with a ball cock valve and float, replace it with FLUIDMASTER. If you want more pressure from your shower head, remove the restrictor from the shower head. If you have hard water install a water softener. TRUST ME on this one! ESP. if your house is piped in copper! Your pipes, washer, fixtures, and clothes will thank you.
