I've been perusing the VOA's and UOA's of Redline oils...
I had initially thought that the typically high wear metals could be explained by actual metal to metal wear (instead of a "washing out" of old metal laiden sludge), in the cases where the Zinc and Phosphorous were being depleted. But some of the UOA's show high Lead and the add packs seem pretty much intact. So that hypothesis doesn't seem to always hold true.
But I noticed something a little odd about the Redline chemistry. They seem to use around 25 ppm of Potassium in all of the blends I looked at (VOA's). But in the UOA's--even on pretty short drains--the Potassium is all but gone. Some members even commented: "Potassium a little high there..." when the ppm was 2 or 3. But again, the Potassium level began high, at ~25 ppm in the VOA's.
Please enlighten me as to the role of Potassium in the mix--no other oils I've looked at here seem to have more than 2 ppm of that element. Most have ZERO.
Could an OD of Potassium be at least partially responsible for Redline's generally less than stellar UOA's?
I'm not a chemist. But I think we have some here...
There does seem to be a warning by Shell oil company regarding Potassium levels in gasoline; it's said that too much can cause valves to "stick." This blurb is referenced in this Bardahl webpage. http://www.bardahl.com/automotive/Products/insted_o.htm
What is it about Potassium that can cause valves to stick? And if it's not good for your combustion chamber, why would it be good in the crankcase?
Just wondering.
Dan
Just wondering.
Dan
