- Joined
- Dec 16, 2022
- Messages
- 1,411
I'm saying: compare a 2020 ridgeline (or whatever) to a 2020 half ton. The half ton will always out tow the ridgline, no matter what engine is in there; because the engine is only piece of the puzzle, the rest of the truck is just so much better for towing. If you want to compare a 2020 ridgeline to a 30 year old half ton with saggy springs and rounded out bushings, knock yourself out, but it's not a useful comparison.Trucks stick around a long time in the West. Lots of 20 and 30+ year old trucks still on the road.
My titan is 20 years old now.
No, I mean a v6 half ton vs otherwise identical v8, the v6 only gets a lower tow rating (in Ram anyway) because of the lower power that the v6 produces; the rest of the truck is identical. The difference in GCWR for a Ram 1500 v6 with the 3.92 and a v8 with the 3.21 is < 1000 pounds.Tow rating on a half ton is more than engine and axle - but also engine and trans cooling, and brakes.
In owning a boat shop and being a boat manufacturer for over a decade I've ridden and towed in just about everything made with my customers and friends , I can say from experience - no body on frame solid rear axle truck rides or handles as well as the IFS/IRS Ridgeline.
My old Grand Cherokee was as good a ride as any ridgeline, built on the mercedes SUV platform (unibody), and though in some areas the GC was different, more refined, my truck is still extremely pleasant just a little more "trucky". Though the suspension is stiffer, the half ton is bigger so I fit better in it, get less physically fatigued, and greatly prefer driving the truck over the GC for any amount of distance. In a few tight parking lots in the city, ok, the GC would win that contest. Towing? GC doesn't have a chance against my truck. My trailer would push that little GC all over the road.
The 2020 ridgeline owner's manual says this: "When towing a fixed-sided trailer (e.g., camper), do not exceed 55 mph (88 km/h). At higher speeds, the trailer may sway or affect vehicle handling."
I don't know any midsize that has that requirement, let alone a half ton. If I'm in a hurry on an empty freeway, I stop at 70 mph in my truck because that's reaching the limit of my trailer tires, the truck itself is still perfectly in control and has gobs of power left with no cooling issues.
And we haven't even begun to compare luxury or tech. No contest, a fully pimped out Ram/F150/GMC absolutely destroys the ridgeline in all these areas. Air suspension, massaging seats, giant pano roofs, massive infotainment screens, HID, cushy leather, "self driving" etc etc. The list is endless.
The half ton is always going to handle the weight much better than the little ridgeline. Longer wheel base, wider track, stiffer suspension, bigger brakes. Objectively speaking, the ridgline is worse when it comes to carrying cargo, it's not an opinion. Even if the payload is identical, the fact that the half ton has a much higher GVWR means it will handle the weight better. And a better metric is to use RAWR anyway, and the half ton has much beefier axles (6 studs, not 5 like the ridgeline), will take more abuse etc.It's not my pick to tow or haul above its weight, but within its window I'll pick it over my three other choices and and every time.
Hauling a bale of hay or even a big block on a pallet is still truck work and its way better ride than a body on frame trucks
I'm well aware of where the thing falls down, and dont pretend its something its not and with two other truck and a suburban to chose from I can pick anything I want.
Great. You obviously prefer the smaller truck, but you definitely "pretend it's something its not" when it comes to hauling/towing, offroad performance etc. But I've said my peace and will move on, I'm not trying to trash your ride,
