If you have upgraded to Windows 10 you might be shocked at the number of features that are enabled to share and send your personal data to Microsoft AND that can easily be accessed by others. I sure was even though I had heard some about this. I took the time this morning to go through and shut all that [censored] off. I suggest you look and do the same otherwise everything you do is sent to someone and people can easily get into your system.
1. - Go to Settings>Network and Internet.
Wi-Fi is the 1st on the list( on left )and should be highlighted. If not select Wi-Fi. Scroll down and click on Manage Wi-Fi settings. This let's you shut off WiFi Sense which gives easy access to your computer via WiFi. Disable both Connect to suggested hotspots and Connect to networks shared by my contacts. This doesn't shut your WiFi off it just closes the wide open door letting others have easy access to it.
2.) - Go to Settings>Privacy.
This is a big one. I had no idea Microsoft was gathering so much info! Start with the General option to the left and work your way down through the list( on left )shutting off all the things Microsoft has enabled by default that collect and send your data out, share your location, allows access to your system features, etc....
Obviously it is your call but as said I was stunned at the amount of things they have enabled to collect data from us. I shut it all down this morning. IMo this kind of thing should be illegal!
