- Joined
- Sep 13, 2024
- Messages
- 9
I am new to oil filter investigations. New to the site, and still learning!
Based upon the ease of obtaining a 'good' oil filter at Oreilly's and disliking the oil change process on a toyota 3.5 V6 I decided to do a longer oil change interval.
In the past I have used the Toyota brand oil filter, and Havoline 5W20 synthetic oil. The engine has 265K.
Thinking I could go to longer on an oil filter change, I got the micorguard select locally, and installed it.
The worrisome thing is on a cold start when the temperatures were below 20* I can hear what sounds like a rod knock...
That is a sharp metallic noise, with some frequency. Heaver sounding then valvetrain/lifter noise, and only when outside Temperatures are one the cold side.. The noise would go away within 30 or so seconds, but that felt like a lifetime to me.
Taking no chances I went back to the Toyota brand filter, and installed 0W20 oil. It's cold out this morning so I will see if the noise is gone for good, or if I am in the process of loosing an engine. I did not see any shiny flakes in the oil filter..
