The one I saw it on was a Wix XP 51372XP-
It‘s in the “detailed description“ section.
Sounds like “proprietary” rock catcher technology to me! I’m somewhat interested if Mann can improve the XP/Platinum at all, the Purolator Boss isn’t that bad!Ok, I called Wix Customer Service (704-869-3421) and mentioned that the Wix website doesn't show any beta/efficiency information for the Wix XP but it does for the regualar Wix filters (typically shown as 95% @ 20u), and asked if they had any information on the Wix XP efficiency they could share.
The gal I talked to said they are told to basically say: "The media configuration is proprietary, and that the efficiency is 99% @ 35u to anyone who asks about the efficiency". She didn't say on which Wix XP filter model that is based on, but it was probably on their largest filter size. She couldn't tell me why Wix chooses to not show the efficiency information on their website when they can give the info to people over the phone.
When I look at all the Wix XP filters lilsted on O'Reilly's website today, I don't see any efficiency reference at all. Maybe it was there at one time, but not now it seems. But if it use to say "99% @ 35u" then that seems to match to what I was told on the phone today.
If you look at Andrew's ISO 4518-12 test data, the Wix XP came in at 62% @ 20u and 88% @ 35u. The filters he used in that test were for a 6.2L Chevy V8, so if it was smaller in size than what Wix bases its XP efficiency number on, then that could explain the difference.
Would you all like to see ISO 4548-12 Oil Filter Lab Testing Comparison, Efficiency & Capacity, Pressure vs Flow, Bubble Point, and Burst?
I have this as a “watched” thread, so if you do happen to start a new one, could you put a note or link in this one to direct followers to the new thread? Thanks!! Yes, no problem I can do that.bobistheoilguy.com
Ouchtown, pop: Wix XPOk, I called Wix Customer Service (704-869-3421) and mentioned that the Wix website doesn't show any beta/efficiency information for the Wix XP but it does for the regualar Wix filters (typically shown as 95% @ 20u), and asked if they had any information on the Wix XP efficiency they could share.
True ... if the XP was the same efficiency as the Boss, I'd put them both on my "I'd use them" list.Sounds like “proprietary” rock catcher technology to me! I’m somewhat interested if Mann can improve the XP/Platinum at all, the Purolator Boss isn’t that bad!
Strange, your link shows the ISO efficiency info in the "detailed description" section. In the link I gave earlier to all the Wix XP filters, when you open any of the XP filters there is no efficiency info in the detailed description -The one I saw it on was a Wix XP 51372XP-
I knew I was special! I just knew I had seen Wix efficiency in O'Reilly's website before. Not that the XP's is any good, that's why it's "proprietary"! Sounds like Ascent 's testing shows it as even WORSE than quoted.Strange, your link shows the ISO efficiency info in the "detailed description" section. In the link I gave earlier to all the Wix XP filters, when you open any of the XP filters there is no efficiency info in the detailed description -
Here's a direct link to the same 51372XP model filter. No efficiency info in the "detailed description" text.
This is the "detailed description" section in your link for the same Wix XP filter model. Your link shows a whole extra paragraph in the detailed description.
Maybe Wix sends the ones with leaking internals to the O'Reilly's on the west coast.I knew I was special! I just knew I had seen Wix efficiency in O'Reilly's website before. Not that the XP's is any good, that's why it's "proprietary"! Sounds like Ascent 's testing shows it as even WORSE than quoted.
